AMD Ryzen 9 7950X 评测
2022-9-27 21:00| 发布者: nApoleon| 查看: 111392| 评论: 77|原作者: DiamondBall|来自: www.chiphell.com
摘要: 尽管自2020年秋天发布的Ryzen 5000系列确实优秀到可以在两年时间内正面顶住三代竞品的压力.但随着对手下一代的新品的发布抬上日程,AMD这边此前迟迟不肯露面的新一代Zen 4架构新品也终于到了“丑媳妇总得要见公婆”的 ...
测试平台
CPU:
        AMD Ryzen 9 7950X (Base: 4.50GHz, Max Boost: 5.70GHz+0.15GHz, Limits: PPT 230W, TDC 160A, EDC 225A)
        AMD Ryzen 9 5950X (Base: 3.40GHz, Max Boost: 4.90GHz+0.15GHz, Limits: PPT 142W, TDC 90A, EDC 140A)
        Intel Core i9-12900K (Base: P-3.20 GHz/E-2.40 GHz, Max Boost: P-5.20 GHz/E-2.40 GHz, PL1=PL2=241W)
主板:
ASUS ROG Crosshair X670E Hero (AMD X670E) (for Ryzen 9 7950X)
ASUS ROG Crosshair VIII Impact (AMD X570) (for Ryzen 9 5950X)
        ASUS ProArt Z690-Creator WiFi (Intel Z690) (for Core i9-12900K)
内存:
        G.SKILL Trident Z5 Neo RGB DDR5 (2 x 16 GB / DDR4-6000 / 30-38-38-96)(for DDR5 platform)
        Crucial Ballistix DDR4 (2 x 16 GB / DDR4-3600 / 16-18-18-38)(for DDR4 platform)
显卡:
        ASUS ROG Strix RTX 3080 OC 12GB (GeForce GTX 3080 12GB)
系统盘:
        Acer Predator GM7000 2TB (2048 GB / PCIe Gen4 x4 / NVMe)
CPU散热器:
        Phanteks Glacier One 360 M25
电源:
        Phanteks Amp Series 1000W
机箱:
        Cooler Master MasterFrame 700 (Test Bench Mode)
操作系统:
        Windows 11 v21H2
测试软件:
        SiSoftware Sandra 21 R16a
        PCMark 10
        PugetBench for Photoshop V0.93.3
        PugetBench for Lightroom Classic V0.93 (LrC 11)
        PugetBench for Premiere Pro V0.95.5 (Pr 2022)
        PugetBench for After Effects V0.95.2 (Ae 22)
        PugetBench for DaVinci Resolve V0.93.1 (DaVinci Resolve Free 17)
        SPECworkstation 3.1.0
        AIDA64 6.75
        CPU-Z 2.02
        wPrime 2.10
        y-cruncher 0.7.10.9513
        SuperPI Mod 1.9 WP
        Cinebench R23
        Cinebench R20.060
        Cinebench R15
        Blender Benchmark 1.0 Beta 2
        Blender Benchmark(new)(Launcher 3.1.0, Blender 3.3.0)
        Corona 1.3 Benchmark
        V-Ray Next Benchmark 5.02
        WinRAR 6.11
        7-Zip 22.01
        HWBot x265 HD Benchmark 2.1.0
        x264 FHD Benchmark 1.0.1
        3DMark
        Cyberpunk 2077
        HITMAN 3
        Horizon Zero Dawn
        Red Dead Redemption 2
        Shadow of the Tomb Raider
        F1 22
        Forza Horizon 5
        League of Legends
        Counter-Strike: Global Offensive
        FINAL FANTASY XIV: Endwalker Benchmark
        World of Tank encore RT
        Sid Meier's Civilization VI
        HWiNFO64 7.30
        Prime95 v30.8
        MSI Afterburner 4.64
室温环境:
CPU设置说明:
本次测试中CPU的功耗与频率设置均依照AMD或Intel对于对应型号的原厂设置规范.即:
  • Ryzen 9 7950X: TDP 170W(for Raphael), 对应PPT/TDC/EDC/TjMax限制为270W/160A/225A/95℃
  • Ryzen 9 5950X: TDP 105W(for Vermeer), 对应PPT/TDC/EDC/TjMax限制为142W/95A/105A/90℃
  • Core i9-12900K: Maximum Turbo Power模式.对应PL1=PL2=241W.
统一选用原厂的功耗设置规范一方面可考察原厂标称设置的性能释放与特性,另一方面则是尽管测试平台上已采用了开放式测试架搭配360 AIO水冷,但在未知根知底的前提下,能更大程度地避免测试过程中可能出现不必要过热问题而无法完成全部测试项的情况出现.
系统内电源配置档统一设置“控制面板”中的”平衡”计划,搭配”设置”中“电源模式”为”最佳性能”.
内存设置说明
内存方面,DDR5的平台统一采用16GB*2/DDR5-6000/30-38-38-96/1.35V设定.即测试平台所用这套G.SKILL F5-6000J3038F16GX2-TZ5NR的标称参数.
目前市场环境下,16GB*2符合主流容量配置,在此基础上标称或可超频至DDR5-6000的产品选择面较广,且几乎不受主板/CPU的型号与个体限制即可达到.同时这组设定仍能保持AMD平台的UClk:MClk=1:1与Intel平台Gear2模式.
DDR4的平台采用16GB*2/DDR4-3600/16-18-18-38/1.35V设定. 即测试平台所用这套Crucial BL16G36C16U4W的标称参数.
同样地,目前市场环境下,在16GB*2下标称或可超频至DDR5-3600的产品选择面较广且几乎不受对应平台的主板和CPU型号与个体差异的限制即可达到,且能保持AMD平台的UClk:MClk=1:1模式
游戏测试项说明
本次测试中游戏测试以“1080p低画质”为主,以更能体现不同CPU/内存平台间的性能差异.
游戏画面设置遵循以下规则:
  1. 除非游戏内置的图像全局预设选项中强制指定了分辨率与抗锯齿选项,否则游戏分辨率均设置为原生1920*1080,并关闭垂直同步,关闭抗锯齿.
  2. 对于设置中存在图像全局预设的游戏,均选择全局预设中最低一档,但不再进一步调低细节设置.并且,如果全局预设内包含渲染分辨率和抗锯齿相关选项,同样不再手动另行指定.
  3. 对于设置中未含图像全局预设的游戏,在保持原生渲染分辨率的前提下,手动设置其余全部可调选项至最低.
  4. 大部分项目采用游戏内置或通用的Benchmark场景.对于无内置或通用Benchmark的游戏采用自制场景,具体说明如下:
  • 英雄联盟(League of Legends): 训练模式下,仅加入单英雄,固定出生位置视角,关闭小兵生成,手动生成所有野怪后,使用MSI Afterburner统计游戏0:30至2:30间的平均FPS. 
引用 chu8129 2022-11-15 19:42
如果能一页列完那就更完美了,视频真的没那耐心看
引用 Wolfensten. 2022-10-20 17:28
没啥问题
tcpip2000: 我决定这代的5950X一直用下去,显卡3090也不再做任何升级了,就这样用到完全淘汰,估计再抗到2025年没得问题吧! ...
引用 tcpip2000 2022-10-8 09:34
引用 S柒儿 2022-10-3 21:08
评测很平直,评论也很纯粹,期待7000的3D版本。
引用 ztqqwwee 2022-10-1 17:30
zbzb: 可能是年纪问题吧,我个人还是觉得图文清晰、条理性强、阅读体验更好!
我也喜欢这样的,看视频太费时,还是现在这样一目了然。过一阵忘了数据进来一翻就好了,看视频多费劲。
引用 wildbear 2022-9-30 20:13
我也喜欢这样的
引用 594WEH米奇林 2022-9-30 11:39
Ryzen 9 3900X 繼續戰未來
引用 komizi 2022-9-30 10:41
没人yes吗?
引用 makxma 2022-9-30 09:39
同感,喜欢有条理的图文阐述一款产品的各项参数。
引用 958813826 2022-9-30 01:33
看了眼主机上的5900X 感觉没啥必要换 等5950X 3D好了 不出就等下代吧
引用 sum 2022-9-29 16:12
这个CPU配合der8auer准备上架的直触套件,使用信越硅脂和D15S散热器,应该完全可以做到“长久安静的陪伴”吧。
引用 zbzb 2022-9-29 16:02
kartanus: 时代变了,个人建议这种首发评测可以出个视频,商配/自媒体已经做了很久,但测试项目少,也不如第六页内容有实际指导意义;也可以整图文+直播,外站直接拉活到网 ...
引用 Ray.D 2022-9-29 11:51
于是最终我们看到的Ryzen 9 7950X,是一个虽然性能可以全方位胜出,但温度也彻底失控,真正能用“出厂即灰烬”来形容的怪物.
经典评论,佐证就是温度,众生平等的95°
引用 BXWS 2022-9-29 11:47
我在看了隔壁家的13系发布参数以后,感觉这次苏妈如果不上市就降价,基本上卖不动了。一点儿性价比都没有了。
这也不能完全怪苏妈,她也想比隔壁卖的便宜,问题是台积电出的价格太高,她又没好好砍价,而隔壁家是自己的公益价格好控制。
总之,不讲价,我是不买了。
引用 angulo 2022-9-29 10:49
极度深寒: CPU贵,温度高;主板贵,内存贵……等等几样副作用加在一起后,这代的锐龙7XXX瞬间成了被大家嫌弃的角色!!
那实际情况确实是这样
引用 lyboo 2022-9-29 09:34
表格评测还是图文一目了然,视频评测效率太低了,更适合产品开箱和展现动态细节上的东西。
引用 极度深寒 2022-9-28 22:17
引用 82485339 2022-9-28 20:12
nApoleon: 每个人的时间和精力都是有限的,大家都是24h,去掉睡觉,可支配的时间也都相差无几,有人喜欢视频,也有人喜欢图文,根据自己的喜好选择好了,CHH从来都没想过要做多大, ...
轮大说得太对了,正是因为这里不太大,并且相对的小众和高端,我都来这十几年了,为的就是玩得开心。好多年前的号,在CHH和GZ的访问量比较中,被扣成了负分。
引用 媳妇漏气啦 2022-9-28 19:59
核显是不是有其他特殊的用途啊
引用 sakura2384 2022-9-28 18:48
13代测评出来了没
查看全部评论(77)
GMT+8, 2025-6-6 17:19 , Processed in 0.009644 second(s), 9 queries , Gzip On, Redis On.
